Enable IPFIX Globally
IPFIX allows you to monitor IPv4 traffic flows. Use the following procedure to enable IPFIX globally.
The default global state is disabled.
  1. In the navigation pane, expand Configuration > IP.
  2. Select IPFIX.
  3. Select the Globals tab.
  4. To enable IPFIX, select enable in the ConfState option box.
  5. Optional: To configure an observation domain ID, type a value in the ObservationDomainID field.
  6. Optional: To configure the aging interval, type a value in the AgingInterval field.
  7. Select Apply.
Use the data in the following table to use the Globals tab.
Name
Description
ConfState
Specifies whether IPFIX is enabled or disabled. The default is disabled.
ObservationDomainID
Specifies a value for the observation domain used to send IPFIX messages. The default is 0 (no observation domain). If the value is 0, data that is sent is not applied to a single observation domain.
AgingInterval
Specifies (in seconds, minutes, hours, or days) the flow record aging interval. The aging interval determines how long a traffic flow that is no longer being received is retained as a flow.
The default is 10 seconds.
